Ernie1
Mini Inferno Battery
Hello all,
Can you put me on the right track ? I have a mini inferno with a battery 8 cells 1100 mah each. Can i charge them with an ultimat 16 charger ? or do i need a special charger? I ask this because there is a special connector on the battery . Until now i have only used lipo and normal tamiya racing packs. Or can i just change the connector to deans and use my normal charger ?
Regards Wim
Hello,
Tried it this morning ( a little bit scared) and it worked perfect. The ultimat has an automatic NiCd program where it detects the cells himself so problem solved. Hope this helps other people to anyway thanks for reading.
Regards Wim
