Apologies for the picture quality!
New scaler based on the SCX-10 B)
AWESOME ! I've been extremely tempted to get the scx10 but now I'm definitely waiting. They really do just keep raising the bar for scalers :P. Nice scoop !
It's in this month's RCCA and for once, you're not B)
According to the squiggly bits, it's got a 'slightly longer wheelbase' than the stock SCX
What with that and the Dingo, they're pretty sorted
I laughed so hard I nearly fell from my chair Andy ! :P
Why is it, you always get the magazine before me ? You are after all, "across the pond" :( .
No idea chap, going by the post on RCC about this truck, the US ones arrived today too B)
i love the look of the dingo, hated the first scx-10 body. which magazine is the rcc.
RCC is a US crawler forum, www.rccrawler.com
RCCA is the mag - Jan 2010 issue
:lol: And it will be terribly expensive to order from the internet. We end up paying through our necks here in SA for anything remotely cool.
Andy it looks cool even if the pic is a little on the grainy side.
Henk :D
The full skinny;
SCX10 KIT w/Trail Honcho Body
  • Based on the popular SCX10 chassis
  • Realistic c-channel steel ladder style frame for that real truck look
  • Molded skid plate for less hang ups
  • Realistic shock hoops with multiple mounting positions
  • Coilover shocks – dual rate springs provide maximum off-road performance
  • Battery tray with Velcro straps makes changing batteries easier and accommodates standard 7.2V stick packs and larger LiPo batteries
  • Enclosed radio box protects receiver from dust and debris
  • Slipper Clutch – enhances the durability of the drive train when in binds
  • Pro-Line Flat Irons tires – Excellent traction and grip on most surfaces
  • Beadlock Wheels – Real beadlock wheels, never glue tires again
  • Proven durability – Axles and transmission are directly from the original AX10 Scorpion
Trail Honcho Lexan Body
  • Photorealistic die-cut premium vinyl decals include window frames, headlight, grille, tail lights and more!
  • Overspray film and pre-cut vinyl window masks make painting fast and simple.
  • Dimple marks for body post drill locations.
  • Made from durable .040” clear polycarbonate plastic for long life
  • Realistic cab with composite plastic molded rear cage with realistic diamond plate bed insert
  • Spare tire carrier/mount
  • Realistic LED headlight buckets
Durable composite rock sliders protect your body from damage and allows you to slide over rocks
Realistic tube style front bumper with aluminum skid plates
Functional spare tire/wheel included!
LED light bucket set – Includes 7 different styles of light buckets to hold 5mm and 3mm LED lights. Also has realistic plastic lenses.
All hex socket hardware
Specs
Chassis Dimensions
  • Wheelbase: 313mm (12.3”)
  • Width: 227mm (9”)
  • Height: 150mm (5.9”)
  • Weight: 1814g (4.0 lbs)
  • Ground Clearance: 68mm (2.7”)
Body Dimensions
  • Length: 457mm (18”)
  • Width: 216mm (8.5”)
  • Height: 137mm (5.4”)
Required Items
  • Electronics
  • Radio: 2 Channel
  • Servos: 1 (Standard Size)
  • Forward/Reverse ESC
  • Motor: 540/550 Size
  • 7.2v Stick Pack Battery
