It doesn't matter what ESC you have, you plug it into a spare socket on your receiver.
Ready made kits are available:
http://www.rcmart.com/catalog/rc-f103-z520...ht-p-27544.html
http://d-drivesportsenglish.com/index.php?...products_id=421
The cheap option is to build it yourself if you can handle a soldering iron.
All you need is a 5mm flashing LED like this one and a resistor. If you are connecting it to a plug that fits in the receiver you want a 47 ohm, 1 watt resistor, if you are wiring it straight into the battery leads you need a 100ohm, 1 watt resistor instead. Wire it like the diagram here and you will have a flashing tail light.
okay thanks alot does any one no if tamiya or anyone else are bringing out like a chassis protector to stop it getting trashed when u play in street
  • 2 years later...
I just made one for my f104,, Just went to radio shack purchased a 5mm 5 watt blinking red led and wired it up. No resistors. Just pluged into the channel 3 of my reciever.
