Hello all,
I have an old Yokomo YZ 10 from 1993 that needs a manual so that I can find and order some parts. Apart from that, I misplaced the motor that it came with while moving houses and none of my Tamiya motor pinions seem to mesh with the spur gear. Now I am not an engineer ;) and don't have a clue as what the "pitch" is or how many teeth the pinion had :) , or if a pinion came with the car kit at all. All I can say is that the spur gear has 81 teeth (it has 81T on the side). Can any of the experts help out a confused fellow?
Thanks,
Anand
It takes a 48dp pinion. Think my Yokomo Dog came with an 18 tooth pinion.
Good luck with ordering parts for it, Yokomo buggy parts are very rare :(.
igbandy,
thanks a lot, will a Tamiya pinion of the same 48 pitch & 18 teeth work?
Thanks,
Anand
Do Tamiya make any 48dp pinions? I thought all of theres where metric pitch apart from a few with 32dp gears.
If your pinion is a Tamiya AV pinion its 0.6 metric, it looks like 48dp but it isnt. And it will damage the spur gear.
Hello again,
I have no technical knowledge regarding pitches or gearing except that they have teeth :D ! I just wanted to know if these will work in the Yokomo YZ 10!
Thanks again,
Anand
Hello again,
Thanks again,
Anand
Yes they would be ok.
Hello again igbandy,
as you said the 18 T pinion works just fine, have'nt tried the 19T yet. I have just started using a Mabuchi RS540 Sport tuned in the Yokomo YZ 10. I am currently working on some mods and also, are there any wheel adaptors so I can use regular wheels & Tires such as the ones on a Boomerang or more recent wheels? is there anywhere I can download any copies of the manual?
Thansk,
Anand
