Worldwide postage available on these via our web site www.goldstarstockists.net - the bearings are high grade, metal shielded ballraces - same as we've always sold but we're now buying straight from the factory and able to pass on the savings:
BEA1 Mr Bear TL01 / Dual Hunter Bearing Set £12.00
BEA10 Mr Bear DT02 Bearing Set £7.00
BEA11 Mr Bear Thundershot Bearing Set £10.50
BEA12 Mr Bear Hi-Lift Bearing Set £20.90
BEA13 Mr Bear Hotshot Reissue Bearing Set £9.00
BEA14 Mr Bear CC01 (Toaureg / Pajero) Bearing Set £9.60
BEA15 Mr Bear Boomerang Reissue Bearing Set £9.00
BEA16 Mr Bear M05 Bearing Set £9.00
BEA17 Mr Bear TXT-1 Bearing Set £19.10
BEA18 Mr Bear M01/M02 Bearing Set £7.00
BEA19 Mr Bear TA02 Bearing Set £11.60
BEA2 Mr Bear TT01 Bearing Set £8.80
BEA2E Mr Bear TT01 TYPE E Bearing Set £10.80
BEA3 Mr Bear M03/04/FF02 Bearing Set £7.00
BEA4 Mr Bear Mad Bull / Lunch Box / Hornet Bearing Set £5.00
BEA5 Mr Bear Blazing Star / Manta Ray Bearing Set £11.00
BEA6 Mr Bear DF02 Bearing Set £4.00
BEA7 Mr Bear Clodbuster Bearing Set £11.60
BEA8 Mr Bear WWII / Blackfoot Xtreme Bearing Set £9.00
BEA9 Mr Bear TLT-1 Bearing Set £14.00
Single BEA1050 Loose 1050 size bearing £1.25
Single BEA1150 Loose 1150 size bearing £0.50
Single BEA1260 Loose 1260 size bearing £0.60
Single BEA1280 Loose 1280 size bearing £0.70
Single BEA1510 Loose 1510 size bearing £0.70
Single BEA840 Loose 840 size bearing £1.25
Single BEA850 Loose 850 size bearing £0.50
