hi all can use the standard pinion gear what comes with lunchbox for 27t stock motor also do u need change for any other types
thanks
The long brass pinion that comes with the Lunchbox is the only one you can really use with any motor because of the size of the big wheels. The pinion will work fine with the standard motor to a motor that makes the MT completely uncontrollable like 5700Kv brushless (what I have in mine).
