Hi all,
I thought I’d show you what I have done with my Motorized Legs,
I wanted to move the trailer closer to the unit but all attempts failed due to the switch for the legs, so I came up with this idea.
Let me know what you think
First I bought one of these
It’s basically an RC switch
Then I done away with the switch (that the servo on the unit works) from behind the plate and moved the pin to the back hole
Next I put the receiver in the pallet box next to the battiest for the leg
and wired it all up
and this is the gap now
I bought a tamiya reefer and built it as a flatbed with the motorised support legs and I moved the king pin rearwards by almost the length of the kingpins plate less 10mm and mounted the switch for the legs in the box under the trailer where the batteries for the legs go
good idea though
good idea though
are you talking about the 3 way switch? If so that is where it fits, I’m talking about the switch that the servo works
ah got it now I did not realise that you had not added the kit under the trailer as per instructions to mount the micro switches at the back of the kingpin plate, I thought that you were on about the switch that you can either mount on the legs or in the box under the trailer, silly me
_________________
