you just need to the body kit as the body mounts for the chassis is on one of the body parts sprues
thanks do u know which part it is there normally labled like a b c d etc
The body mounts are on the E Parts sprue and are likely to be found between the hens-teeth and rocking-horse poo, seeing as they have a tendency to break in anything more than a passing breeze.
I think you can try your way with aftermarket body posts, but that will require some extra work and inventiveness. Good luck with the Pumpkin. It really is a fun truck to run!! :)
