hi been on ebay and wondering if these shocks will fit the lunchbox item numbers on ebay are
220551981211
220552061588
be great if u could get back to me as there ending tomoz night
cheers
:) Don't know what those shocks are that you are refering to. Sound somewhat like older Boomerang shocks looking at the part no. I used Tamiya CVA's part no 50519 on my one Pumpkin and they work a treat. I can suggest those. Hope that helps.
Henk :rolleyes:
You can use just about any shocks on the lunch box if they're at least 80mm or so.If they're longer just take them apart and put some pieces of tubing on the shafts beneath the pistons to reduce the length.This will however put more preload on the springs so you may wanna swap them for shorter or softer ones.
