Hi guys..
Just got hold of a nearly unused Leopard 2A6 tank, but the manual is missing, and the controls were located wrong on the TX, and after assigning the functions to the correct sticks, the setup is not correct any longer, so could someone please scan the manual for me, and upload it here? All i really need is the parts showing and explaining the setup and special features operations. (combination of? movements). I simply cannot remember how to setup that DMD-unit, lol..
Any help is much appreciated, because right now, it can run, turn, rotate turret and raise and lower the gun, but no machingun or primary gun sounds, and the trim-levers are not centered for it to drive now, so it defenitely needs a new setup. :blink:
Thanks in advance..
Michael
hi is this what you are looking for, it is the page from the manual on how to set up the tx to the DMD
I have misslaid the little book that tels you what the functions are when you move the trim levers
Yes, that´s the setup-sheet.. THANKS! :) Perhaps someone else has the "how-to" guide explaining the functions?
Cheers..
Michael
I also need someone explaining how to adjust the VR-trimmers on the DMD-module. It seems they are the reason for no special-functions working now. :) Of course, i could just start from one end, eliminating possibilities, LOL.. However, SHOULD someone have the manual for fine-trimming the VR´s and using the stick-combos, i would love to know how it is supposed to be done?
Cheers..
Michael
Well, don´t bother anyway. :) I started the elimination-process, and now everything works as it´s supposed to. :D
Thanks for the scan, BRELs. :)
Cheers..
Michael
