Hi guys. Having a mare this afternoon...when i turn my car on (TC3) and the transmitter the steering goes left. Even with the steering trim i can't get it straight. the servo horn is a screw on type, not the sort you jam on like with tamiyas. Any ideas? Do i unscrew and reposition then tighten the screw?
Thanks in advance. Hope you are all well.
IF all else fails, go back to the manual.
From memory, The TC3 manual states that the servo horn ball sits 1/8" or 3mm to the right of vertical. First, power up your radio and car, and center ALL trims and adjustments, then adjust the servo horn to the servo. Fine adjustment on your radio then should allow you to trim your steering.
