well i was relly looking 4ward to using the tl01, with her new wheels and tyres, and lightweight chassis, but 5 mins in of going very fast indeed, and a nasty grinding noise appeared from the rear gbox, so stripped it down and found this, my new lightweight chassis melted around one of the gear shaft holes. not happy! =(
That's strange - that would sort of suggest that the shaft itself was turning. Did you use bearings on the shafts? Apparently the lightweight chassis isn't really worth using - the material isn't strong enough. When you rebuild it, I'd recommend using carbon fibre gear shafts too - you can make them yourself from a kite spar (ask for an offcut from a kite shop - 5mm, hollow IIRC)...
hi, it seems they were the only standard bronze bearings left to replace in the whole car, oops, nevamind gotta get 2 more ball bearings for it and a new chassis as the old one isnt much better, i was going to get the carbon gearshafts too, was really impressed with the pace off the thing till it went wrong. another trip to the modelshop. =) heres a sneaky pic
Before you do any serious running of TL01, it should have full bearings - you need 24x 1150.
Tamiya gives 2 bronze bushings for the spurgear... but if you
under OR overgrease it, it will seize onto the shaft
and overheat the shaft = melted chassis plastic.
Very common TL01 failure.
Carbon shafts doesn't fix it, save your $.
Lightweight chassis or not, both melt the same.
Lightweight chassis isn't recommended for offroad TL01/B use
but its still plenty strong.
quote:Carbon shafts doesn't fix it, save your $.
id="quote">id="quote">
I was suggesting making them for free - I've got a homemade propshaft and gearshafts in mine, which work a treat. Might not fix the problem, but if the car is going to be dismantled, might aswell put them in...
yeah i will get the carbon shafts, they are cheap and i only need 2 bearings and a new chassis, and then it will be like new again, but fast. =)
5mm carbon Kite spars eh?
Nice tip, will have to drop into a kite shop one day.
(and hopefully walk out WITHOUT buying a u-beaut box kite... [:P])
I've been cutting TL01 shafts from K&S bronze & ally tube.
Anything would be lighter than the depleted plutonium that T uses. [:)]
