TitaniumXRC 0 Posted March 8, 2010 This looks like some kind of electric motor clutch pinion drive This is a spline 12mm hex drive. Not sure what size hex drive this spline drive is. Share this post Link to post Share on other sites
berman 5315 Posted March 8, 2010 The bottom two pictures are of wheel and bevel gear hexes for a clod buster Share this post Link to post Share on other sites
WillyChang 1814 Posted March 8, 2010 clutch pinion could be off an old AYK Hirobo etc... its quite small ya? just looks different being blown up so big Share this post Link to post Share on other sites
Origineelreclamebord 45 Posted March 8, 2010 The bottom two pictures are of wheel and bevel gear hexes for a clod buster Isn't that 12mm spline hex drive from the TB01 chassis LA Arms set? My TB01 has the Long Arms Set fitted and has narrow spline hex drives on it. As it's a touring/rally car they are 12mm, and they have the offset ring on one side... Share this post Link to post Share on other sites
TitaniumXRC 0 Posted March 9, 2010 Isn't that 12mm spline hex drive from the TB01 chassis LA Arms set? My TB01 has the Long Arms Set fitted and has narrow spline hex drives on it. As it's a touring/rally car they are 12mm, and they have the offset ring on one side... The offset ring is on both sides of the hex. First picture is of a kyosho slipper clutch setup..this was a first attempt at making a slipper setup to save the first generation ball differentials. Kyosho marketed it with different pinion sizes. Problems were the pinions were made of soft steel and wore out very fast, faster then the plastic clutches. and you were very limited on pinion choices. even numbered teeth were easier to find then odd numbered. it also required a special gear cover to be used, there was a separate one for the old ultima gear boxes. It didn't catch on and eventually kyosho like everyone else moved the slipper to the spur gear. Wow! That answers most of my questions. all but: What do I do with these? I have 10 tooth X 2 sets, 12 tooth X 2 sets, and 18 tooth X 2 sets. Share this post Link to post Share on other sites
