quote:
Originally posted by Mr.Pink
Can i add spacers somewheres ? or better yet how can i modify the stock friction type shocks so i have a lower ride hieght ?
id="quote">id="quote">
Add spacers around the damper shaft inside the shock bodies to reduce the rebound travel. This should work for both the friction and oil shocks.
- James
Limiting the travel with internal spacers will give unusual handling, because the suspension will have no droop.
My recommendation would be the Tamiya Short Touring Spring Set - I forget the part number - or even cutting a couple of coils off your springs. This will stiffen the rate and decrease ride height.
Best way is to get the Super Mini CVA dampers which have also a smaller shock body and allow more drop, they don't cost the world.
