The group C tires are larger than most F1 tires, except those that fitted on the F1 dish wheel set front wheels and the F103L Indy car wheels (but those tires are the same part numbers as the group c tires).
So group C tires will fit all of the group C rims + the front rims of the F1 dish wheel set + the F103L Indy car rims. They won't fit other F1 rims.
If you have a tire cutter you can also fit PRO10 tires to those rims, but you'll need to glue the tires into place using cyanoacrylate glue and keep them in place with rubber bands until the glue has dried. Once the glue has dried you'll also need to cut the tires to correct the width.
The F1 tires have a smaller inner diameter than the group C tires and will fit on all F1 rims (except the Indy car rims and the F1 dish wheel front rims, obviously).
