Ive snapped the arial off on my old school acoms technisport, any ideas on if I can fix as I love it????????????
Split the case in half
Unscrew antenna or pull it out?
Replace with another, generic possibly? won't know till you try
Can't recall which one the technisport is....but the arial should simply unscrew and can be replaced with another standard arial easily found on ebay for a few pounds.
As dazza says, most antennas simply screw in - you shouldn't need to open up the case. If you think how often they are likely to get broken off, it makes sense that they would be replaceable reasonably easily...
True, I just told him to split the case to see if it is screw on or what,just to be safe, but you don't have to.
