Hello
I've received the above in a 'job lot' that I've brought from eBay. (Specifications can be seen here: Click on 80amp
Their website has a copy of the setup documents but nothing to indicated what turn/kv motor it can handle.
Reading various threads on forums and looking around on ebay it seems that 80amp should be enough to handle 5800kv fairly easily, but at the same time I can't find anything definitive.
That speed would also probably eat the gearboxes of anything I have to put it in!
The other thing is that it is brand new with no connectors. I realise I need to use deans or something similar for the battery but what about for the motor? Are they just a certain mm of bullet connector or do they have a special name?
Any advice gratefully received!
Regards,
Dave
I would expect that ESC should have no problems running an EZY-RUN 5.5 turn motor, given that the EZY-RUN 5.5T combo includes a 60A esc..
The motor connectors used on the EZY-RUN's are 3.5mm "Corrally" style bullet connectors..
