I used to use a drill. :)
Once I discovered hole reamers, no going back for me. They work perfectly, cause no real danger of messing up the shell, and can be used in a pinch to stab something if need be.
Cheers,
Skottoman
what u guys use to make nice round,clean holes in lexan.?
either a drill or a reamer.
reamer works the best for me since its pretty controllable as compared to a drill that could spin out of its target.
I've never slipped with a drill yet (touch wood) as I start with a very tiny drill at very low rpm and then increase drill size and speed until you get to the magic 6mm or 4mm depending on what your fitting to a shell like mirrors and spoilers etc. :)
Rich
I don't have a body reamer yet, but I plan on buying one. For now I use a drill and try to be careful, starting off with a small drill bit and then drilling increasingly larger holes in the same spot. I also always use a wooden block below the part of the body where I drill to make sure I don't mess up the lexan. With Tamiya shells it's not as necessary to be very careful though as with shells from some other brands, like Carson.
And like mentioned before, for a good finish on a shell, use a Dremel - they work absolutely perfect! :)
i hold a drywall screw at the point with some needlenose pliers....take a lighter and heat up the head of the screw....mine came out perfect every time :lol:
it punches out a perfect circle....i did this with my rc10 body...you might wanna grab a different size screw for tamiya stuff....
