Jacko Boy 0 Posted July 6, 2010 help in am in australia trying to get my 2010 scorcher to the beach, i forgot my crystals so i have purchased some futaba ones 27.095mhz, put them into my acoms gear and the whole thing has gone nuts? what is the problem are the futaba crystals not compatible?they are am? help i need to hit the beach Share this post Link to post Share on other sites
Olly_Lunchbox 28 Posted July 6, 2010 Are they in the right way round? Sounds daft but I only just found out a couple of months ago that they are TX and RX specific. One will have a T on it somewhere for the trans and the other will be marked with an R for receiver. Share this post Link to post Share on other sites
Jacko Boy 0 Posted July 6, 2010 tried that, i am a bit confused really unless its interference? only thing ive doe is unplug the motor before I brought it here, i also added a alluminium chasis plate maybe that is causing interference? dont know really maybe aussie crystalls are different - have tried to re set the esc but it wont seem to let me, the red light just keeps flashing with the steering going nuts Share this post Link to post Share on other sites
Zak001 0 Posted July 6, 2010 tried that, i am a bit confused really unless its interference? only thing ive doe is unplug the motor before I brought it here, i also added a alluminium chasis plate maybe that is causing interference? dont know really maybe aussie crystalls are different - have tried to re set the esc but it wont seem to let me, the red light just keeps flashing with the steering going nuts Id have a good look around....if you look very closely you may see TA Mark with a big grin on his face on the same frequency Share this post Link to post Share on other sites
stu22 12 Posted July 6, 2010 What frequency was your Acoms originally on? Share this post Link to post Share on other sites
bjr250 23 Posted July 6, 2010 tried that, i am a bit confused really unless its interference? only thing ive doe is unplug the motor before I brought it here, i also added a alluminium chasis plate maybe that is causing interference? dont know really maybe aussie crystalls are different - have tried to re set the esc but it wont seem to let me, the red light just keeps flashing with the steering going nuts I would be looking at the usual suspects. Interference - try rerouting the receiver wire also don't test inside near big metal objects like fridges or balcony railings. Bad connections - unplug and re-plug everything back together just to make sure that nothing has come lose. Rx and Tx crystals swapped Bad gear - the crystals (or the other radio gear) could be stuffed. Gear mismatch - I have a Futaba set that just will not work with Acoms crystals and a mate that has the same problem with an Acoms set and Futaba crystals. There is no explanation for this some individual radio sets just won't play with others. Finally make sure that if your radio is 27MHz that you got 27MHz crystals - we also use 29MHz in Australia. Share this post Link to post Share on other sites
berman 5315 Posted July 7, 2010 Interference - try rerouting the receiver wire also don't test inside near big metal objects like fridges or balcony railings. Coffee/nose Hahaha I mis-read that and had a mental picture of a guy in a fridge with a transmitter I agree with everything bjr250 said above, I also have futaba/acoms stuff that doesn't work together Share this post Link to post Share on other sites
HunterZero 76 Posted July 7, 2010 Sounds like you've possibly installed 27MHz crystals in 29MHz radio gear. This doesn't work... 29MHz radio gear only works with 29MHz crystals. Acoms gear can also be twitchy with Futaba crystals in, you need Acoms crystals. - James Share this post Link to post Share on other sites
Henk4Focus 0 Posted July 7, 2010 Id have a good look around....if you look very closely you may see TA Mark with a big grin on his face on the same frequency Coffee/nose Hahaha I mis-read that and had a mental picture of a guy in a fridge with a transmitter :) Yip, that's me rolling on the floor laughing!! Henk Share this post Link to post Share on other sites
TA-Mark 195 Posted July 7, 2010 Wasn't me I'm on FM and 2.4Ghz Share this post Link to post Share on other sites
Henk4Focus 0 Posted July 7, 2010 Wasn't me I'm on FM and 2.4Ghz Share this post Link to post Share on other sites
taliesin 260 Posted July 8, 2010 Wasn't me I'm on FM and 2.4Ghz The lad protests too much, me thinks.... Share this post Link to post Share on other sites
