Does anybody know what upgraded shocks i can get to fit my stadium blitzer? The hop up ones mentioned in the manual are virtually impossible to find unless someone has some there selling?
Your right about the 53036 shocks there very rare indeed to find, but the 53037 are readily available.
Yes you have the 53037's on your site but i dont see the point in buying them unless i get the fronts too, Have any stashed away anywhere?
Lol, i did not actually mean my site (but your right they are), i actually meant in general terms, they are still available on ebay regularly, where the 36's are not so much, you have to be quicker than the re-sellers lol (not me). Sorry dont have 36's for sale im afraid.
DF03 dampers are the right length. It's what I've used on my Blitzer Beetle chassis'd Bear Hawk.
Would the 53926 kit fit mine?
That is the set I've used. I have used the kit spring though and not the ones from the 53926 set as they are the right weight for the chassis. You will need to fit 8 ball screws to the chassis to mount the dampers on (not in the 53926 set).
You can build them slightly shorter if need be by putting an o-ring on the shaft inside the damper body to limit their free length. It was a while ago I fitted them and I think I did this for the fronts only.
Does the 53926 kit make the truck sit hoghler/lower or at the standard height? how does the truck jump with them fitted? Thanks
