I did it by modifing the shocks.
First I recommend you order 53155 oil shock set if you haven't already got'm, then instead of using the short bottom mount pieces, use ones for the Baja Champ/Wild Dagger, order 0005688 rrp £6.99ps.
Thats how I raised the ground clearance on my Stadium Raider, I then fitted a set of Wild Dagger wheels with a set of Schumacher 2.2 tyres. I haven't altered the gearing to compensate for the larger wheels and I've not had any problems either.
Check my showroom for pics.
