Hey guys,
We're currently in the progress of refurbishing my old Clodbuster, and i've been really considering upgrading from the single servo in center set-up, to dual servo's (one on each axle).
if you look wayyy back i made a topic about wiring up a TEU-103BK ESC on a clod, now i need you guys to answer a new question: will it handle dual servo's?
cause i've heard that two servo's might put a strain on the BEC circuit
servo's will most likely be some Futaba S3003's
I'm terribly sorry if this is a rather stupid question to ask, but thanks in advance
ever think about a hi torque metal geared servo on the front only instead ? . i did away with twin steer , now , you can move the front wheels nearly through the whole steering range , not all the way but a lot better than with the nornal twin steer set up . other than than , most servo's run of 5v .. so you might be safe running a esc with thermal shut down like the tamiya esc . i run a 103 with stock motors on mine
