i have a focus tlo1 chassis and i am a bit confused about something. are the mb1 step screw - 4x11.5 the same as the hop up tamiya aluminium king pin set 53157? if not any idea what the part number is for the standard step screw? cheers.
The 53157 is hop up for the 4x10mm stepscrew. What you might use is the 53141 lightweight kingpin set. I don`t know the nr for the normal stepscrew sorry.
The standard step screw is in Bag 'B' which is part #9415333
If the screws are available seperatly I don't know??
If you're after a set of standard screws then I've got some you can have, they're used but still ok
53157 are Aluminium king pins, but NOT for the TL01 chassis as they're only 10mm
53141 are the TL01 ones
