post-33202-1284325985_thumb.jpgI purchased this item from Ebay. The rear swaybar kit looks to be an old Trinity. I have mounted up the aluminum section to the rear gearbox, that is no problem. The issue that I am havin is the two small blue "slider" pieces. I am having difficulty mounting the two small aluminup pieces to the rear arms. The problem I am having is the ends of the sway bar slide through these then I guess you have to also run a screw through the aluminum piece to secure it to the rear arms. Also, do the ends of the sway bar go into the K7 and k3 rear parts? Ive looked at a lot of pictures on the internet and It looks easy but for some reason mine will not install easily. Does anyone have any trinity swaybar instructions from back in the day?
I had one, 22 years ago!
1. Attach the front mounts to the trailing arms.
2. Slide the rear mounts onto the swaybar.
3. Unbolt the rearmost bolts from your gearbox.
4. Slide the swaybar ends into the mounts on the trailing arms.
5. Line up the rear mounts with the holes in your gearbox and replace the bolts.
6. Marvel at your newly installed rear swaybar.
(edit) you may need longer gearbox bolts.
Yep. What 92gsr said! I got the CRA set for my Mudblaster which needs to be mounted the exact same way and I needed longer bolts aswell.
That makes sense, I failed to install the front mounts to the trailing arms first. Duh!! Im glad I posted here. That was very helpful. Thanks folks
