hi all
im so sure there are plenty of guys here who have one of these bad *** rod kits?
my problem is that i have a roller and no idea how to set it up to run...i have tried searching the net and this site and dont seem to be having any luck.
anyone got one and some time to answer some questions or......
a scan of the manual would be sooooooo sweet
cheers in advance
Brett
ok...maybe i should be more specific...
what sorta pinion do i use on this kit?
does anyone have a pic of how they have setup the electronics?
any help would be wonderful
thanks
Brett
anyone?
Its as basic as a pan car gets really, Pinion is what ever pitch the spur is, the steering servo goes between the front wheel with a directlly mount servo saver, Just taped in should be fine. Use a ESC. It will never preform very well by pan car standards,but should be fun to drive and look at.
If you want more details post pictures with the body off and I can help you more.
thanks. how do i figure out what the pitch should be?
trying to figure out what pinion to use mainly...also wondering how you have mounted the hemi?
let me check tonight and come back.
Get a 48-pitch pinion, nice and small (14-16 tooth), and a big roll of servo tape. Literally everything in the car, including the hemi motor, is just stuck down with tape. I have a standard 540 silver-can in mine, and it's plenty of power.
Here's where I have everything mounted in mine:
Don't expect miracles from this car, though. It's stupid-fast in a straight line, barely turns at all at any speed above a crawl, and has virtually no brakes. Good times indeed! Give yourself plenty of room with this one.
