Anaerobic Gel Thread Lock
Item #54032
Tamiya is now releasing a new easily applied screw lock gel for helping in the prevention of looseness in metal parts in R/C vehicles. It can also be applied on chassis' as well engines.
Liquid Thread Lock - X7329
Item #87004
This is Thread Locking Compound from Tamiya. Must be used on metal or steel items, not plastic. Do Not use this on plastic, as it will melt the plastic! Color is blue. Apply thread lock to the threads before installing. Prevents the screws from working loose,which will happen if it is not used. It is very effective and easy to use. Screws can be loosened or removed for maintenance by using about twice the force required when they were originally tightened.
I noticed that there are at least 5 different greases:
AW grease
Cera-grease HG
Molybdenum
VG Cup and joint
Ceramic grease
What specific Tamiya applications would these different greases be used on?
Molybdenum Grease
Item #87022
Lithium is the base material in the grease, moly is an additive in the grease. Molybdenum disulfide is a dark gray powder that is very hard and very slippery. Moly is excellent for slow moving, heavily loaded points. This grease is suitable for gears and moving parts in mechanical operations. It maintains its viscosity over a wide temperature range, reduces friction, and has molybdenum properties that cover the entire surface well. Use moly-additized grease on the sliding spline on the driveshaft. Moly can contain abrasive particles that can damage needle, ball, or roller bearings.
Ceramic Grease
Item #87025(DISCONTINUED)
This grease is formulated using Boron Nitride particles, and is ideal for use on electric powered R/C vehicles. It should be applied to all bearings, shafts, and gears. It maintains it's viscosity throughout a wide temperature range.
Cera Grease HG
Item #87099
This Cera-grease HG is made using Boron Nitride which gives it superior lubrication ability. Cera-grease can be used with MINI 4WD cars, R/C Cars, Robocraft gears and bearings, and provide excellent lubrication for plastic and metal parts.
RC Anti-Wear Grease
Item #53439
The potential of this grease has been race proven as one of the valuable components of the TRF414 chassis, greatly reducing friction between moving parts. High viscosity grease ideal for use on differential gears.
RC VG Joint/Cup Grease
Item #42128
This new Joint & Cup grease is best suited to fast moving parts. It assists in preventing wear and tear on parts. Other types of grease which have been used in the past tend to dry up and cause stiffening. With the new grease, there are no drying up and stiffening effects making this the grease to have for fast moving parts. The grease is a blue color.
There are a bunch more TRF "VG" greases as well:
- 42130 Thrust bearing grease (a black Teflon grease for diff thrust bearings similar to associated)
- 42129 Damper grease (to make shock o-rings smoother like Associated Green Slime)
- 42169 TRF ball diff grease (probably thicker like Associated or Schumacher)
- 42170 Diff plate grease (I imagine is to stick the diff rings to alloy outdrives)
Tamiya also has three friction damper greases (53174 soft, 53175 medium and 53176 hard). In addition, they also sell these in a 3 pack of 2g tubs for mini 4WD cars (15129).
  • 1 year later...
Thanks Smegs! 2 years on this thread is still helping newbs like me. Wish i had found this 2 days ago!
moly is best as it doesn't get flung out as easy
but in recent models we're now going towards gear diffs made to be filled with silicone fluids of varying thickness
According to a review i read on the following page Molybdenum Grease is best used on Gear Diffs ...
It's all I've ever used since my very first Tamiya and that same diff is still going without being opened since it was first built some 25 years ago.
www.rcscrapyard.net/tamiya-ferrari-fxx-tt01.htm
LOL! All it says is "My recommendation is to use molybdenum grease.". What kind of a review is that?
Anyways, the stickier the grease you use, the better the limited slip effect. For that reason I always recommend anti-wear grease for old-style open gear diffs. It's WAY stickier than moly grease, and it definitely won't get flung out either.
  • 4 years later...
18 hours ago, ALEXKYRIAK said:
Is Cera-Grease HG different to ceramic grease, or is it the same thing?
I took would like to double check before buying some
Totally agree, Anti-wear grease works amazingly well in gear diffs.
James
It's a different compound but used in the same way. Not sure actually answers your question though. Technically it's different but functionally it's the same.
If it's functionally the same, I guess it answers my question! Thanks.
I personally just use generic grease from the motor factors the same stuff you put in a grease gun for grease points like king pins and bearings or CV joints. Seems to do the job grand.
What is that little tube they give you with the kits? That's the stuff I like, simple and effective.
I've also had some luck with Magic Lube which is a ptfe (Teflon/nylon) based water resistant lube for swimming pool valves. I just don't like that it's super sticky and a pain to remove if you ever need to.
  • 3 months later...
Hi guys, I'm restoring a Hotshot2 from 25 years back...
I haven't oppened the diferentials yet but I suppose I'll have to put new grease on them, as the cups too and all moving pieces.
Is the Anti-wear grease the best option for it? works well between plastic and metalic axle (wheel arrm)?
Thanks for your time
