Hi Guys,
Does anyone happen to have or know how I may be able to get hold of a Samurai gearbox?? I've taken mine apart to ballrace it and its falling apart!! :lol:
Many thanks :lol:
Hi Guys,
Does anyone happen to have or know how I may be able to get hold of a Samurai gearbox?? I've taken mine apart to ballrace it and its falling apart!! :(
Many thanks ;)
Do you mean the casing, or the gears inside?
The casing may be:
Side Cover Set 106 -500
Inside there is available (with part numbers):
Rear Diff Set 109 600
Bevel Gear (Large) SET 117 -700
Pinion Gear Set ( C ) 130 -250
These may not be the parts you need. If you can get me the part numbers of what you actually need I may be able to help you.
The casing may be:
Hi there, I sent you a private message did you receive it ok? Basically I just need the side casing to the rear gearbox, I believe it is part number C10 and C13 from the 'C' parts tree of course! :D
Hi there, I sent you a private message did you receive it ok? Basically I just need the side casing to the rear gearbox, I believe it is part number C10 and C13 from the 'C' parts tree of course! ;)
YEAH GIVE ME A FEW DAYS TO TAKE A LOOK in my stuff (sorry caps lock on)
