how can i get oil dampers to fit my grasshopper 1 will the rear oil shocks of the hornet fit
Hi Grasshopper 1
The Hornet shocks will fit on the original Grasshopper. If you are using re release parts you will need plastic sprue D parts from the Hornet - part number 9005156, Hornet screw bag A - part number 9465639 and Hornet damper parts bag - part number 9400273. With the screw bag A and the damper parts bag you will have parts left over you might want to use as spares. These parts will also allow you to modify the Grasshopper front springs to Hornet friction dampers.
Hornet kit assembly instruction books can be found on the net if you need help. If you need more help please let me know
Have fun
Buggy Boy in Australia
The GB01 TamTech dampers worked on my Grasshopper. I did cut the standard damper towers off the front however and am using a CRP FX-10 front suspension setup.
