Hi Guys
Is there a simple way of raising the ride height for my rising storm - just acquired off the Bay and it looks low - havnt tried it out yet but looks like it will struggle on grass - any views or ideas?
Many thanks in advance
4 computer motherboard mount pegs with machine screws threads. They will extend the dampers about 6mm each. Add them between the damper shaft and lower eye, effectively making the shaft longer. This is what I did to mine.
Or you can measure the CVA dampers and buy longer dampers.
Adding long dampers or extending them as I did makes for some nasty positive camber. I opted for a DF03 turnbuckle set so I could get adjustable upper and steering links to get the camber and toe back in check.
The brass hex parts in this picture.
Thanks TA Mark
Gorgive me - what is computer mother board pegs - are they the brass things in your photo? -
Is the DF03 turn buckle set a buyable option for this buggy?
Amateur many apologies
