Dombrasky
M05 Advice
Hi All
Just bought a m05 with a TA03 diff,Raced it for the first time the other nite
had far too much steering,so decided to tighten the front diff,after removing
both driveshafts,could not find adjusting nut,my questions are;
Do you have to remove this diff to adjust it ?
If so do i have to split the whole car in half to remove it ?
yes
yes, half of the front part (gearbox) anyways
M05 ball diff is externally adjustable, its main & only advantage
You can adjust the tightness on the M05 diff with an alan key without taking the chassis apart, out of interest were you racing at Chippenham?
Hi Deane,
No i wasnt at chippenham but may go there soon,are there many minis Race there ?
Hi, yes there were 5 heats and 2 of those were just minis, probably around 12 cars in total.
The last meeting for this year is next Tuesday night from 630pm
Thats a shame ive a micro meeting on that night
Il defo come over in the new year tho,im racing in with no rule mardaves at the moment ,and my new shell got badword of a bashin already
see ya in the new year if ya there
Dom
I would go for a real M05 diff, and drill 8 more 3mm holes and add 16 tungsten/ceramic balls. This should make it very very durable and super smooth, even when adjusted to be tight.
If you are getting the M05 diff, get the TRF416 Diff Nut and Screw. The stock M05 diff nut and screw is so weak that you can't get the diff tight enough without snapping the screw. With that said, just tighten up your TA03 diff (remember to add lock tight on screw) and leave it in your mini and forget about it. I had my TA03 diff for 2-3 years without the need of rebuilding. The only thing I had to replaced is the stock diff cup, which I upgraded to the harden ones.
with TA03 diff also worth gluing the cups in at the splines, use shoegoo
unglued they will rattle and the splines will wear down until they strip
