Gmade TS01 Scale Shock Red 90mm (with Internal Soft & Hard Springs)
Main features:
  • CNC machined Aluminum shock bodies and Delrin pistons
  • Red anodized shock bodies
  • Upper and lower shock ends includes blue anodized aluminum balls
  • Internal soft and hard type springs
  • 4.5mm thick shock shafts
  • Shock boots protect exposed shock shafts
  • Easy load shock seal assembly
  • Fits Gmade R1 rock buggy, 1/10 scale crawlers & trucks (such as Axial SCX-10, Tamiya High-Lift)
What's included:
  • Red anodized aluminum shock bodies x 4
  • Soft and Hard type springs x 8
  • Shock Boots x 4
  • Shock absorber silicone O-ring x 8
  • All necessary hardware to finish the shocks
  • Shock Grease
Specs:
  • Length: 90mm (Mounting hole to hole)
  • Full Shaft Travel Range: 20mm
  • Shock Body Diameter: 11mm
  • Shaft Diameter: 4.5mm
Note: This shock does not require shock oil
Gmade TS02 Scale Oilless Shock Silver 90mm (with Internal Soft & Hard Springs)
Main features:
  • CNC machined stainless steel shock bodies and delrin pistons
  • Silver finish
  • Upper and lower shock ends includes red anodized aluminum balls
  • 8mm thick shock shafts
What's included:
  • Shock bodies x 4
  • Shock absorber silicone O-ring x 16
  • Shock Grease
Specs:
  • Shock Body Diameter: 12mm
  • Shaft Diameter: 8mm
Available from Junfac
