I went with the Ansmann ARW3200-13 which is 13T, 32dp. They do a ARW3200E-13 version for 5mm motor shaft if thats what you need.
How well it goes, and how well it matches, i can;t say because I only got my brushless ezrun set in the mail this morning !
So for the Hotshot which uses 0.8 module(i think) these Robinson Racing?(have to use the 5mm to 1/8" adapter)
http://www.robinsonracing.com/catalog/brus...ion.html#.8-mod
I know that 32dp is very close but i want to use something that is exactly the same.
As they are listed for E-maxx, they would almost need to be 32dp, which is so close to 0.8mod you won't measure the difference. Traxxas own pinions for the E-Maxx are listed as 32dp.
These Robinson Racing pinions are also for a 5mm motor shaft, not 3.2mm, They do have a reducer listed at the bottom for adapting them to 540 motor applications.
I've been using Traxxas 32dp steel pinions in all of my 0.8mod models.
