Just odered a set of alloy D Blocks for my Dyna Storm.
Pargo 2000 is doing them in alloy.
At Least if i break them i will be able to fix it.
Good thinking from pargu but once there is a better nylon version out i will switch.
Pargu is indeed doing them in alloy - but unfortunately he made dips for press nuts - which doesn't work to well as you may have experienced :huh: I suggest you put a spacer in each hole and put a pair of nuts on top of the block, and it should work just fine.
I am still working on my project for the moulded plastic suspension block. My last exam for the next week or 6 will be done tomorrow - so my focus will be back on the project then. I need to choose between releasing it soon and using materials I tried to avoid using - or taking lots of time to make it perfect (like I chose for so far). The chances are getting increasingly smaller that I'll actually be able to mould the actual parts cheaply to the standard at which I'd like them to be, so I might have to choose the first option.
Pargu is indeed doing them in alloy - but unfortunately he made dips for press nuts - which doesn't work to well as you may have experienced :) I suggest you put a spacer in each hole and put a pair of nuts on top of the block, and it should work just fine.
What ever you choose to do put me down for 2 sets.
Just want to run my new D/S. Didn't want it broken on my shelf.
Keep up the good work.
OK who is making these, and how do I purchase? I need a good 2wd runner to go with my EVO and 2011 Avante?? How do I order?
Pargu2000 on ebay - he is also a forum member here, so you could PM him as well and ask him about it. It seems though that he is mainly here for doing business, so he might refer you to his ebay store :) I can refer you to the topic where he refers to his auction, but I think that although not against the rules, it's still not meant to happen...
Just search Dyna Storm on ebay and it's among the list - easy to find as the list isn't as big as with modern cars :)
