Does the ratio that tamiya lists in their manual final or just the pinion/spur ratio?
I want to put a superstock RZ and the recommend ratio(i think its the final ratio) is between 6.5 and 7.5
http://tamiyaclub.com/showroom_model.asp?c...846&id=1386
And the hotshot manual with 17t pinion i get 7.6 ratio
So this mean that the RZ will be ok right?
If i use a 13t i would be able to get even more torque(loose speed) but less amp draw?
I just want to make sure that im comparing the correct ratio terms together....
Those suggested ratios are for on-road. Buggies have somewhat larger tyres so you would need to go maybe 20%-30% higher on the ratio.
