Hi everyone another question from a newbie,
i got the Rooster ESC from Novak, the crawler version.
The motor cables do not have any bullet connectors and they should be weld directly on the motor.
Is that a must or i can choose any other type of connector?
For example instead of a bullet connector can i use Deans connectors?
Thanks.
sorry because as i said i am a newbie...what do you mean power poles?
It's another kind of connector. Not so popular now as it was 5-10 years ago. Deans is as close to a standard as you will find now if you want concealed contacts.
Personally I would solder direct to the motor as it is not a part you often replace.
