hi , i just bought a battered old frog of good old eblah . with it came a le mans 360pt motor ..i found info on that one no worries , ita a single turn 19t with bearings and replaceble brushes , its also advanceble in both directions .
the others are yokomo twinturbo 360 gtr and the other is a yokomo twinturbo 360 gti . the gtr is a double wind motor while the gti is a triple wind motor . has any body used these motor or have any info on them ? a search of the web found litttle .
I only have info about Kyosho motors and i'm happy to help with them.
KYOSHO MOTORS
240WS = 18 turns with 0.65mm wire and ball bearings
240S = 19 turns with 0.90mm wire and ball bearings
240ST = 22 turns with 0.80mm wire and bronze bushings
240SB = 19 turns with 0.65mm wire and ball bearings
360PT = 19 turns with 0.90mm wire and ball bearings
360ST = 22 turns with 0.85mm wire and bronze bushings
360G = 18 turns with 0.65mm wire and ball bearings
480WT = 24 turns with 0.40mm wire and ball bearings
480S = 24 turns with 0.80mm wire and ball bearings
480T = 26 turns with 0.75mm wire and ball bearings
480G = 25 turns with 0.40mm wire and ball bearings
All but the "ST" motors have adjustable timing.
Bye
WWD
