I bought a used M-05 Pro which has (I think) some kind of speed tuned gears, so when I try to install a motor the default holes doesn't seem to line up to get the gear mesh right, does anyone have any info on this or is it me that suck?
The speed tuned gears are probably from 3Racing. Depending on what spur is fitted inside the car, you'll need to go either 2 or 4 teeth larger than the standard pinion to get it to fit.
