.. which came in a job lot of rubbish !
1. no markings on these, 51mm diameter at the tyre bead area, 35mm overall width, no hex drives..
2. no markings, 54.5mm diameter at tyre bead, 35mm overall width, 12mm hex drives - outer faces have slightly textured finish. Possibly from a pick up / monster truck ?
3. Single yellow wheel, 12mm hex, 51mm diameter at tyre bead, 35mm width
4. Single Blackfoot or mini Clod type wheel ? 12mm hex, 56mm diameter at tyre bead, 51mm overall width
5. Real oldball ones now, maybe from an old pan type car ???
Big hex drive (not measured but probably 16mm or bigger), overall width of rim 65mm, rim diameter 54mm. Fitted with directional v grooved foam tyres, labelled Arrows tyres..
Any help in identifying what they are appreciated, although not sure what use i can put them too !
thanks for the info..
first ones defo looking like the RS500 Cosworth you suggested
second ones are looking like Optima Pro rear wheels now i've looked at some images
found the yellow one on ebay - Kyosho SM-79 Outrage wheels by the looks of it.
think the 'mini-clod' type ones are Kyosho too - UM-70 Outlaw ?
