I've just got my original Schumacher Cougar down from the loft after it being in storage for nearly 20 years. It all seems in good working order apart from I need to new servo horn(?) to connect the servo to the steering rod.
In the instructions is says use a servo saver with a spring and I cant seem to find one, anyone know where I can get one from to fit a vintage Acoms servo.
You can probably just use a standard Tamiya one. The spring is plastic, but they work OK.
E.g. Tamiya 50204 Servo Saver Set. It will fit Acoms too.
