I guess a silly question but does any turn above 27 work fine with the MFU? I want a slower motor but don't want to risk damaging £200 of electronics
Yes, some of my friends run from 55 to 85 turn Integy motors on MFU without any problems. :lol:
The more turns, the less power it uses nad less revs..
However, the engine sound sometimes get a little inaccurate.. But again, it does that even with the kit-supplied motor. :lol:
I use the carson poison motor now in all mine. Works much better then the standard motors!
Ant
I have a Carson Truck Puller in mine and while the speed is fine it has so little torque that it gets snagged up a lot when not on a perfect level surface. Would the Poison motor be any better? I am tempted to go back to a crawler motor.
Get an Integy motor instead of trying all those Carson-motors..
The "tests" here sofar has proven every Integy-motor better than any Carson, so i suggest getting an Integy Matrix Pro lathe 75 turn motor.
Otherwise, the Servonaut TM72 is also a good motor, and good value for money, i still prefer the Integys though.. :(
Cheers..
Michael
I used to run an Integy 45t lathe motor but that was a bit too fast - I think I will try something similar but with more turns.
