Simple question really, how interchangeable are the part sprues for the Frog and Blackfoot series with the Monster Beetle.
I've already got a pukka MB chassis (cage) and gearbox on the way, plus most of the front suspension and the rear corners.
I've ordered a Frog rere pressed metal parts bag for the front suspension stays (u shaped channel that the wishbones etc bolt to)
I still need the lower front section that the bumper bolts to - can i use the Frog rere one ?
I still need the J parts and E parts but guess i'll have to stump up good money for those, plus possibly the G part tree for the rest of the body mounts (not bothered about the spotlights)
The large part that covers the servos looks similar to the one i have on the KBF - it might not be 100% identical but would this fit ?
Many thanx
Hi,
Yes you can use the H parts for the attaching the front bumper and suspension and you can use 'C parts'
Regards the servo cover, yes, if you use the KBF speed controller plate.
On the MB the plate is metal and the cover is cable tied to it, on the KBF the plate is plastic and the cover is screwed to it.
Hope this helps.
Do you have a manual for the MB or frog?
Regards
Many thanks for the replies - I do have the manuals for original and rere frog,all the blackfoot series and mudblaster plus monster beetle. I've been comparing manuals but the parts are slightly different in places as you confirmed. Will be using esc so opens up my options for the servo' cover.
