Front and Rear Shock Towers for Tamiya Frog, Subaru Brat, Blackfoot, Monster Beetle, Mud Blaster
Main Features:
  • CNC machined aircraft aluminum
  • Comes with multi mounting holes for 1/10 EP buggy oil shocks
  • Silver anodizing finish
  • Exceptional quality and finish
  • Easy installation
  • Fits Tamiya Frog, Subaru Brat, Blackfoot, Moster Beetle and Mud Blaster
What's included:
  • Front shock tower x 2
  • Rear shock tower x 2
  • Aluminum spacer x 8
  • Brass shaft x 4
  • Installation screws & nuts
Click Here to order direct from Junfac, but probably available from Fusion Hobbies soon too
Great items, ordered from fusion hobbies, all I need now is the 50 caliber rear arms and my frog based bitza will be ready for some rough stuff :)
EDIT
I tried but couldn't check out so will get them from Junfac
This is awesome. I wonder how soft the front springs are.
That would depend on whether you took the originals out and the strenght of the units you fit. I'll just be putting dampers on mine using the original springs.
BTW it was £10 cheaper to order them from Korea, I expect it may take a bit longer to get ther though.
Sweet stuff! I was going to sell my Brat Scorcher because the custom front shock setup doesn't work too well, but I might be tempted to throw this mod on and keep it now!
I've looked through the Junfac site but couldn't see these shocks on there, I've also trawelled through ebay and towers site looking for them.
So I've now tried the obvious and e-mailed them, I'll post up when I get a reply.
Rich
Thats the page I found. I thought shocks were shocks and could be used for different uses so long as they were the right length. If those are no good I don't know of any others they do. There are quite a few companies that do shocks for RC vehicles, maybe the ones in the picture are from a different supplier.
My parts arrived on Saturday. Very high quality items that fit perfectly. The front towers in particular are beautifully machined. There are no instructions, but if you use the pictures online it is fairly easy to work out. The front works realy well positioning the shocks (in my case I am only using the shocks, keeping the original springs) perfectly, so they operate with no binding (more than could be said for my efforts).
I have fitted the rear supports but not the spacers as yet as I have to sort out a better shock/spring unit and the rear arms.
