Hi good people!
The steering servo saver on my dt-02 seems to always loosen off from the servo everytime when I drive it on rough terrain and I'm getting quite sick of it! Does anyone have this problem too? Would appreciate some help, please...!
Thanks, good people!
I had the same problem today after doing some jumps. I think a slightly longer screw should solve the problem, since the 10mm screw recommended in the manual is a bit short. Plus, be sure to choose the correct screw type to match your servo.
Super glue.
It works for me. It holds when in use and it will come off when needed.
This is for servos with a plastic output. For metal output use blue threadlock.
