hi guys just read my instructions prior to starting my first build.
noticed the kit according to the parts list comes with 3 X "MD2 BUSHES".
in section 2 it shows you to cut 1 MD2 in half and insert in MR15 (rear gearbox)no problem.
then in section 19 again cut 1 MD2 in half and put in the front gearbox propeller joint.no problem
do you put the other half in the rear gearbox propeller joint as it does not appear to instruct you to do so???? :o
also in section 7 there is no instructions to put the final "MD2" in MR15(front gearbox) IS THIS CORRECT??? :unsure:
is the 3rd MD2 BUSH a spare?? :unsure:
apart from the above the instructions seem ok
cheers a first timer
in section 2, u r suppose to cut the MD2 in half and insert each half in the Left & Right MR15, so both the MR15's has a MD2 in it.
in section 19, its up to u if u wish to insert the other MD2 half to the rear.
as for the 3rd MD2, yes, its spare.....
hope tis will help
regards,
