Picked up a nitro thunder chassis on evilbay yesterday - i'm intending adding it to my winter project list and doing a brushless conversion with a EZRun 4300kV system. Hopefully that will be sufficient for reasonable speed (don't want lunacy!).
Transmission 'spur' gear is 57T, so will be going with a 13T pinion as per the original clutch bell housing.
Just need to know what the pitch is - 0.4M/48dp or 0.6M/64dp ?? or even 32dp ??
Nitro is usually Mod1. Bigger teeth than 0.8 module. Most Mod1 pinions for brushless conversions have a 5mm bore. The Ez-Run motor has a 3.2mm shaft.
