Meakz1973
Grasshopper lexan shell body mounts
Hi guys,
I'm building a Grasshopper for my nephew's Christmas present. I'm using a Parma lexan shell so he doesnt scratch the hard body to pieces within a run or two.
I need certain body posts to mount this shell on the GH chassis, can anyone tell me specifically which posts I need to buy????? I've looked everywhere for this info.
Thanks!!
I believe Parma intends you to use the posts from a Hornet kit, or they assumed that you would only use their lexan GH body with a Hornet chassis.. I have one of their GH shells at home and can double check the instructions to make sure..
You will need the "D" parts from a Hornet kit to get the mounts. Specifically D4 & D5 for the rear mounts and D10 for the front mounts. Their installation is covered in steps 4 and 14 of the Hornet manual. There is a good chance that you might have to install the Hornet rear shock setup as well, so that everything fits correctly when the rear body shell mounts are installed..
I have never tried to mount the stock GH shocks to the Hornet rear mounts, so I am not sure if it will work..
Hope this helps.
Thanks for the response.
I also emailed Parma and this is how they replied:
"The clear tube set #10450 is correct for it. It has instructions showing the chassis."
