novaturbo 0 Posted January 3, 2012 Can anyone recommend a 7.4v lipo to fit the buggy champ? Thanks Keith Share this post Link to post Share on other sites
bromvw 744 Posted January 3, 2012 Can anyone recommend a 7.4v lipo to fit the buggy champ? Thanks Keith Turnigy LiPo 2200mAh 2S 7.4v 2S1P 20C 30C Burst - ebay . This will be ideal so long as your housing it within the rigid radio / battery box . Specification: Minimum Capacity: 2200mAh Configuration: 2S1P / 7.4v / 2Cell Constant Discharge: 20C Peak Discharge (10sec): 05C Pack Weight: 130g Pack Size: 105 x 33 x 16mm Charge Plug: JST-XH Share this post Link to post Share on other sites
tamiya monkey 243 Posted January 3, 2012 Turnigy LiPo 2200mAh 2S 7.4v 2S1P 20C 30C Burst - ebay . This will be ideal so long as your housing it within the rigid radio / battery box . Specification: Minimum Capacity: 2200mAh Configuration: 2S1P / 7.4v / 2Cell Constant Discharge: 20C Peak Discharge (10sec): 05C Pack Weight: 130g Pack Size: 105 x 33 x 16mm Charge Plug: JST-XH I will second this battery, i use the 2200mah 2cell turnigy packs in all my vintage tamiya inc my srb, the nano-tech ones are great too clicky Share this post Link to post Share on other sites
Capt Splatt 1 Posted January 3, 2012 I used these packs too. To bring them up to size to stop them rattling around (and to give them a little more protection) I wrapped them in wet suit material (an old mouse mat) and then sealed them in heat shrink. I've got 4 of them and I use them in all my vintage runners. At around $10 a throw from HK, you can't really go wrong. Share this post Link to post Share on other sites
tec319 0 Posted January 3, 2012 I also have a few 2200mah 2cell turnigy packs i use both my srbs. i also put a voltage alarm on them with 2 sided tape for low voltage protection because the supplied speed controller isn't set up for lipos. Share this post Link to post Share on other sites
Chapel 5 Posted December 18, 2014 what about these mounted side by side or stacked? http://www.hobbyking.com/hobbyking/store/__17274__Turnigy_nano_tech_5000mah_2S3P_30_60C_Hardcase_Saddle_Lipo_Pack_ROAR_APPROVED_.html or this with the discharge cable changed out http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=23821 or this http://www.hobbyking.com/hobbyking/store/__28006__Turnigy_3600mAh_2S_12C_Lipo_Receiver_Pack.html 12C too low? Share this post Link to post Share on other sites
njmlondon 570 Posted December 18, 2014 Has anybody tried any of these shorties... http://www.modelsport.co.uk/reedy-wolfpack-3800mah-shorty-7.4v-25c/rc-car-products/370757 http://www.modelsport.co.uk/orion-2s-7.4v-carbon-pro-4500mah-100c-li-poly-shorty-pack-battery-w-tubes/rc-car-products/384849 Share this post Link to post Share on other sites
Chapel 5 Posted December 18, 2014 100C? isn't that a bit much? Share this post Link to post Share on other sites
njmlondon 570 Posted December 18, 2014 100C? isn't that a bit much? Probably a tad too much Share this post Link to post Share on other sites
SteveU30 1011 Posted December 18, 2014 Unless of course you intend to do drag runs with Clod wheels on! Share this post Link to post Share on other sites
redzone 212 Posted December 20, 2014 Scroll down my thread to see the turnigy 4000mah shorty I fitted to mine http://www.tamiyaclub.com/forum/index.php?showtopic=72047&hl=champ Share this post Link to post Share on other sites
SteveU30 1011 Posted December 20, 2014 Just remembered about this guide also: http://www.tamiyaclub.com/showroom_model.asp?cid=122994&id=29487 Share this post Link to post Share on other sites
Chapel 5 Posted December 22, 2014 I got a saddle pack http://www.hobbyking.com/hobbyking/store/__59168__Turnigy_nano_tech_5000mah_2S3P_30_60C_Hardcase_Saddle_Lipo_Pack_ROAR_APPROVED_AR_Warehouse_.html I did some significant measuring (I took a tape measure and measured like SIX WHOLE TIMES! ) and figured I can get this to fit. These new radio receivers are TEENY! I got it to fit between the ESC and the antennae mount, so all my electronics are up top. I might get some plastic and mock up my own upper tray that is more solid for all the electronics and then cut it for the wire passthroughs. Is there a good material to use for this that's already the right thickness? Share this post Link to post Share on other sites
hammerstien 187 Posted December 30, 2014 http://www.tamiyaclub.com/forum/index.php?showtopic=73009#entry538678 Share this post Link to post Share on other sites
gt6++ 29 Posted December 31, 2014 I got a saddle pack http://www.hobbyking.com/hobbyking/store/__59168__Turnigy_nano_tech_5000mah_2S3P_30_60C_Hardcase_Saddle_Lipo_Pack_ROAR_APPROVED_AR_Warehouse_.html I did some significant measuring (I took a tape measure and measured like SIX WHOLE TIMES! ) and figured I can get this to fit. These new radio receivers are TEENY! I got it to fit between the ESC and the antennae mount, so all my electronics are up top. I might get some plastic and mock up my own upper tray that is more solid for all the electronics and then cut it for the wire passthroughs. Is there a good material to use for this that's already the right thickness? Wow 5000mah! You can run for hours, if not, days....... Share this post Link to post Share on other sites
Chapel 5 Posted January 1, 2015 it totally fits too Share this post Link to post Share on other sites
