Just found this on Modelsport
2:43 onwards
Losi released first information on the new XXX-SCB line of realistic looking 1/10 scale 2WD RTR Short Course buggies. The off-road cars base on Losi's highly successful XXX platform and sport Short Course truck dimensions with a total length of 510mm and a width of 290mm. The buggies come with a 2.4GHz radio system, LM-32K brushed motor and LiPo-compatible speed controller. Ball bearings and oil-filled shocks as well as a scale-looking buggy bodyshell round off the package. Looking at the pictures it also seems that the SCB sports realistic front and tail lights as optional parts! Available soon in different liveries.
Features
  • Detailed driver figure and cockpit
  • Aluminum, adjustable oil-filled, coil-over shocks
  • LiPo-compatible ESC
  • LM-32K performance motor
  • Spektrum SR300 receiver with 2.4GHz DSM technology
  • 3-gear transmission with sealable differential
  • Adjustable slipper clutch
  • Digital steering servo
  • Durable, composite-molded XXX-chassis
  • Losi exclusive Eclipse SCT treads on XXX-SCT Wheels
  • Off-road beadlock-style wheels as used on the XXX-SCT
  • 3-piece Lexan full-scale inspired desert buggy body
  • Realistic off-road bumpers and roll cage
  • Captured hinge pins
Product Specifications
  • Type:Short Course Buggy
  • Scale:1/10
  • Length: 20.078in (510mm)
  • Width: 11.42in (290mm)
  • Height: 7.24in (184mm)
  • Wheelbase: 12.95 in (329mm)
  • Weight: 4.25lb (1.92 kg)
  • Motor or Engine: Losi LM-32K performance motor
  • Speed Control: LiPo-compatible ESC
  • Radio: Spektrum 2.4GHz DSM Losi radio system
  • Shock Type: Coil-over, oil-filled
  • Ball Bearings: Complete
  • 7 months later...
Oh i like that , agree about the body though . Wonder if a re re champ shell would fit ???????????????????????????//
It'd look pretty silly - there's about 80mm difference in wheelbase
  • 2 months later...
While i was picking up some paint ect from the store i was having a look in this months RC Racer . Came across Losi's new SC / Buggy . Wow i just have to get one of these .
Whilst browsing ebay tonight i spotted a UK seller advertising these at £79.99
http://www.hobbyking.com/hobbyking/store/u...idProduct=18737
Equipped with a 35A brushless system, oil filled shocks, and fully adjustable suspension, this 1/10 2WD Desert Buggy is ready to tear up your local track!
The Turnigy 2WD Desert Racing Buggy performs just as good as it looks. Its 3300KV brushless motor provides plenty of torque, and an impressive top speed. On a 2S lipo, it will pull the front wheels off the ground easily when running on pavement, but this machine really shows its capabilites off road, tearing through the corners and soaring over jumps.
The Turnigy Desert Buggy comes almost ready to run, just add a 2S lipo batttery, 2CH radio system, and you are set to go!
*This buggy features a full metal gear transmission and adjustable slipper clutch
Spec.
Motor: Brushless Inrunner 3300KV (3650 size)
ESC: 35A Brushless (35A Constant, 85A Burst, w/reverse) (XT-60 discharge plug installed)
Battery: 2~3S Lipo (2S recommended) [Required]
Length: 465mm
Width: 290mm
Height: 170mm
Battery Tray Dimensions: 188x27x49mm
Required.
2S 4000~5000mAh LiPo
2CH Radio System (Rx/Tx)
Not suggesting in any way its as good as the Losi, but it doesn't look bad for the money, worst case you take the brushless out if the buggy breaks !
