Torhaantje 66 Posted January 28, 2012 Hi all, I am in the middle of my Bronco project: http://tamiyaclub.com/showroom_model.asp?c...561&id=5123 I am plannig to paint the lexan body on the outside, because I don't like the shiny look of the body when ainted on the inside. What kind of preperations should I make and should I use PS or TS paints? All tips are more the welcom! Rick Share this post Link to post Share on other sites
taliesin 260 Posted January 28, 2012 TS paint simply won't stick. PS paint is designed to etch into Lexan and is the only good paint to use. Otherwise the paint will just flake and peel off. Share this post Link to post Share on other sites
elsworth 0 Posted January 28, 2012 hello well if i was doing what u are doing i would first clean the outside with mephs and the spray with flexible plastic primer ( you can get both in any auto shop eg halfords ). i have sprayed car bumpers and wing mirrors with this and its lasted until i sold car. iam a painter and decorator by trade and use plastic primers and loads of plastics over the years. hope this helps. Share this post Link to post Share on other sites
TongueTied 56 Posted January 28, 2012 How would a matt or satin clear coat work directly on the lexan? The reason I ask is that painting lexan from the back gives your paint job some protection from scrapes and rolls etc. If you were to do a normal paint job from the back but spray a couple of coats of matt or satin clear over the outside of the lexan, you could get ride of the shiny finish you don't like but still get the protection lexan offers. Just a suggestion. Share this post Link to post Share on other sites
spudtrooper37 1 Posted January 28, 2012 Hi, I painted my Hotshot from the outside with PS paint, i did find that temp affected the out come Cold = Matt finish Hot = Satin finish Share this post Link to post Share on other sites
taliesin 260 Posted January 29, 2012 Seems to me that I read about someone scuffing up either the inside or the outside of the Lexan shell to give a matte finish. It may have been something in TC member Wyoming's showroom? Share this post Link to post Share on other sites
bjr250 23 Posted January 29, 2012 You could always paint on the inside as normal and use Tamiya PS-55 Flat Clear on the outside. Link This would give you protected colour coats and a flatter finish. Just don't forget to mask any windows on the outside as well. They can look a bit odd with a flat finish. Share this post Link to post Share on other sites
Percymon 2184 Posted January 29, 2012 This thread may be useful http://www.tamiyaclub.com/forum/index.php?...173&hl=Rust Share this post Link to post Share on other sites
KEV THE REV 2319 Posted January 29, 2012 Hi all, I am in the middle of my Bronco project: http://tamiyaclub.com/showroom_model.asp?c...561&id=5123 I am plannig to paint the lexan body on the outside, because I don't like the shiny look of the body when ainted on the inside. What kind of preperations should I make and should I use PS or TS paints? All tips are more the welcom! Rick I've painted many lexan shells on the outside with success , see my King Cab here http://tamiyaclub.com/showroom_model.asp?c...35&sid=5280 It is painted with Halfords plastic primer / filler base ,with Halfords primer for each colour ,then Halfords top colours - no lacquer coats Share this post Link to post Share on other sites
bromvw 744 Posted January 29, 2012 I've painted many lexan shells on the outside with success , see my King Cab herehttp://tamiyaclub.com/showroom_model.asp?c...35&sid=5280 It is painted with Halfords plastic primer / filler base ,with Halfords primer for each colour ,then Halfords top colours - no lacquer coats + 1 Halfords plastic primer . Once you have a good base away you go . I'd key the lexan with 800 wet and dry first though to give the primer something to bond to Share this post Link to post Share on other sites
mr crispy 2293 Posted January 29, 2012 You can loose the glossy lexan look easily by spraying the outside with a matt varnish. Ive used a normal modelling Humbrol varnish to dull a few lexan bodies and it works extremely well. The varnish sticks to the lexan very well, just remember to mask any windows or headlight lenses you want to stay clear. The benefit is your paint work stays protected on the inside. Look at the bottom of the thread below (post #16) for a lexan Beatle body that's been painted on the inside with normal modelling acrylics, then sprayed with a Humbrol matt varnish rattle can on the outside. It goes very very matt http://www.tamiyaclub.com/forum/index.php?...c=62173&hl= Share this post Link to post Share on other sites
Torhaantje 66 Posted January 29, 2012 Guys thanks for all the input sofar! Painting on the inside and adding varnish on the outside never crossed my mind! Hower: the colorscheme I am aiming for, should be easier applied to the outside...mmmmh If painted on the outside: is Tamiya plastic primer as good as Halfords? And after priming should I use TS or PS paints? Rick Share this post Link to post Share on other sites
lawdog 23 Posted January 30, 2012 Here's a link to a nice tutorial discussing ways to get a matte/flat finish, including the rust-through look: Share this post Link to post Share on other sites
