Yes you can use an ESC in a WW1, i use it!!
Look my runner in my showroom and click on the the Pic called "inside" and you'll see it.
With motors that can be easely used on WW1 without too much mods (sock 540 black endbell, black motor sprint and endurance red & blue EB) every good ESC will work without problem. With those motors it will run cold also if inside the radio box.
Mine runs with a stock 540 and 2000 or 2400 NiCd.
Please do not modify the original radio box it's a murder........ [:D]
Bye
WWD
Hi Willy,
I've an Associated Runner Plus ESC w/Reverse - I know these are cheap n' cheerful - any problems likely with this???
thanks
Paul
quote:
id="quote">id="quote">
It's more than enough and it will runs cold also if you plan to add a modified motor!
Have fun with the Willy!!
Bye
WWD
Runner is made by LRP I think... is it blue?? [:)]
Biggest problem with fitting ESC to WW1 is the steering servo. Once you lose the MSC servo the poor steering servo has nothing to sit on. I've seen some guys cut a block of wood size of servocase to sit the servo on, or just stick a dead old servo in there.
Yep it's made by LRP - looks more green than blue to me (although I am a bit colour blind!). There's a pic here: http://www.hobbiesr.com/asc/asc-esc/asclrp8305.htm
Have thought about the steering servo mounting thing - I was gonna cut a block of wood for it, but I've got a bunch of old servos from various recent deals so will just stick one of those in it. Have also considered using an old servo case stuffed with lead weights to change the handling!?!? [8)]
Nah, makes no difference.
Tie it to the bumper instead. [:)]
(why do you wanna stop Willy wheelying anyway??![?])
I got an old Willy body a while back where some one had managed to melt it by letting the resistors get tooo hot - not sure what they were running through it.
Any way I was about to chuck it, when I decided to having a go at fixing it and all the talk here of speedos made me think about posting the results... Heres the various stages.
Classic melted bonnet
Gotta make it worse before it gets better
Put a sheet of platiKard underneath and build it up with some more pieces
Fill it...
Sand, spray, fill - repeat until happy
The bit that is still warped is OK, as most of it is hidden behind the dash board. I know it was a nice flat area to fix but I was still quite pleased with the results.
chris
That's a great repair job Chris, and an excellent illustration of the way to do it!
My WW1 Runner has got all the bits but a cracked front grill - I was going to have a go at casting a new one in resin - anyone tried to do this before???
Paul
basically i just got some A4 sheets of plastic card from the LHS. Stuck a big piece under the hole, virtually the whole of the underside of the bonnet (you can see it through the body mount hole)
Then cut some more pieces to the rough size of the hole and stuck them on top. The lots of fillings and sanding to get it all down to the same level and hide the join.
chris
chris
Thanks you've been of big help.
I hope that we will see it soon on a WW..! [8D]
Bye
WWD
Sure will - plus i've got two more willys on thier way making a grand total of 5 ww1's and a ww2!
Great collection!! [:P]
At the moment i'm "only" at 4 Wild Willy M38 (2 short wheel base and 2 long WB) and 2 Wild Willy 2, but i'm still growing...... [:D]
Soon i'll update my showroom.
When a Wild Willy repro decal????
Bye
WWD
Hi there,
just in case, it is of interest for anyone, you find my steering servo solution below:
I just took a servo with broken tabs, cut the rest of the tabs off, sanded the "bottom", mounted two aluminium tabs with double sided tape onto the servo, and the whole thing with double sided tape onto a speed control mount.
Regards
Martinid="Comic Sans MS">id="size3">id="red">
Nice job. I wish that I had seen that earlier. I had a Monster Beetle shell that had two front supports snapped in 1/2. I ended up trashing the shell.
